It is currently Mon Jul 28, 2025 1:19 am
PostPosted: Fri Sep 09, 2005 3:44 am
I'm confused I thought I had this all figured out, but now I'm wondering if I really do understand.
This is the process of preparing my sides...I'm not using a side template that has the radius cut. I just leave my sides at 5", bend, glue in the head and tail block leaving the back side of the blocks proud and the top side blocks flush with the sides.
Ok, now here is the question...I then put my sides in the 28' radius dish and sand until there is no daylight keeping it even all the way around by measuring every few times all the way around to make sure I'm not taking too much off of one side. After I'm done my top now has a 28' radius. This means that the upper bout and lower bouts are lower than the middle. If that is the case, when the fretboard extension comes up to the soundhole, won't it be going uphill because of the radius? If that is the case, won't the end of the FB extension hit wood near the soundhole and the neck joint should have a gap. I know a lot of you sand this area flat with one of those fancy jigs, but it just looks like a huge gap from the middle of the side to the head block. Should this not be very much of a gap? By the way, this is not happening on my guitar, but I'm helping others and I see it happening on other guitars. I'm wondering when we go to glue the FB extension if this will be a problem. Can someone comment on the distance from the middle bout to the head block on the top side with a 28 or 30 ft radius if you hold a straigedge flat? How much gap should there be?
PostPosted: Fri Sep 09, 2005 4:09 am
You are correct I get past this issue by shimming the upper bout so that from just past the upper waist through upper bout are not radiused on the tops. Also on the back I gradually pivot the axis of the sanding bowl to achieve a radiused taper starting at 2" low of the waist center through the upper bout to achieve the final upper bout tapper heitht on the back to side joint.
P.S. I am hand snding using a sanding bowl that is suspended on a all-thred rod screwed into a barrel nut seated in a slot cut in my bench. This allows me to pivot the the sanding bowl as required while maintaining constant perpendicularity to the sides.
clear as mud?
PostPosted: Fri Sep 09, 2005 4:22 am
Michael
Could you explain that again. I'm having the same problem. Makes the top of my guitar look like a bunny ski slope.
PostPosted: Fri Sep 09, 2005 5:03 am
Clear as mud! I understand what you mean. I was thinking of making my upper bout flat too on my next. So does that mean put a piece of wood under the upper bout as I radius the top side in the radius dish?
PostPosted: Fri Sep 09, 2005 5:49 am
i believe you are speaking of the upper transvers brace and the upper trans vers graft. I put no radius on these braces. I radius the x-braces tone bars and finger braces but not the upper transvers braces.
second explanation:
I have a 1/2" barrel nut that swivels on one axis mounted in the work benck. Screwed into that barrel nut is a 12" long 1/2" all-thread. I have a 33/64" hole in the center of my sanding bowles. I put a two nuts, 1/2"id x 1"od washer, sanding bowl, washer and nut. This is the sanding machine. I put the rim in the mold and assemble the sanding machine. adjust the height of the saning bowl amd center location along the centerline on the rim assembly so that I sand the portion of the rim desired equally perpendicular to the centerline of the rim assembly. On the back I move the center locaion of the sanding bowl to 2" rear of the waist and no titlt and sand till the tail block is fully radiused. then a bit at a time I tilt the sanding bowl towoard the upper bout sanding as I go till I get to the required height and the bottom of the neck block is fully radiused at the neck/upper bout joint this gives a good clean radiused transition from the lower bout height to the neck joint height. My rim is pre profiled for the back so there is really not a bunch of sanding to do. The top square profiled and the procedure is pretty much the same except I dont radius much past the waist toward the upper bout.
Now I am sure this is really muddy
PostPosted: Fri Sep 09, 2005 5:57 am
[QUOTE=tl507362] Clear as mud! I understand what you mean. I was thinking of making my upper bout flat too on my next. So does that mean put a piece of wood under the upper bout as I radius the top side in the radius dish?
Tracy[/QUOTE]
I know I said i shim and I use to but now days I just tilt the bowl a bit towoard the lower bout (not much maybe 1/2 deg) and slowly work the tilt toward the upper bout, adjustin the sanding bowl height as I go till I get to where I want to stop the radius That way I don't have shim, but I do have to touch up the blend between radius and no radius by hand that takes a whole 2 min by hand. MichaelP38604.6267361111
PostPosted: Fri Sep 09, 2005 6:39 am
PostPosted: Fri Sep 09, 2005 6:54 am
Michael
Am I correct in thinking the radius dish can rock backwards and forwards ?
PostPosted: Fri Sep 09, 2005 7:12 am
Yes but the way my tie downs are set up I can lock it in any position as long as I dont yank real firm. I have pins that locate an lock the mold in position on the benck Dawgs as it were.
PostPosted: Fri Sep 09, 2005 7:17 am
Michael,
I think I know what you are talking about. In that picture, which side is the lower bout? Right or Left? Also, we are talking the TOP of the sides where the top will go right? I understand the back angle and radius okay, but it was the top that was throwing me. Am I correct in thinking that if if you radius your top in the upper bout, then the fb extension will hit the top just in front of the sound hole leaving a gap at the body/neck joint? If you set the neck angle to get rid of this gap, then won't the neck angle be too extreme, meaning that the bridge would have to be too tall to play comfortably?
Also, if you don't radius the upper transverse brace and the graft, then do you glue on a flat surface in the go-bar deck?
Tracytl50736238604.68
PostPosted: Fri Sep 09, 2005 7:48 am
The sketch is more of a reprasentation of doing the back. on the top the tilt almost neglisable like I said a 1/2 deg at the most. If you tilted more than that the bridge would set atifically low.
PostPosted: Fri Sep 09, 2005 7:59 am
Thanks Michael
I think I have it.
So once the dish angle is set you can hold the plane as long as the dish is not rocked too much ?
Russell
PostPosted: Fri Sep 09, 2005 8:11 am
yep. I made my barrel nut 1" in dia my tie downs have less than full radius so the tighter I tighten the tie downs the firmer it holds. They are held down with 4 1/4-20unc bolts. The barrel nut by the way is brass and knerled where the tie downs cross it
PostPosted: Fri Sep 09, 2005 12:10 pm
So Tracy, if I understand your question/problem right, your worried about the gap at the front of the body between the underside of the fretboard and the top due to the climbing of the radius you have put in the rims and now transfered to the top once glued on. So, I layed this out on cad and the average distance from the front of the sound hole to the front of the body is 3.8-4" respectivly. If you have a 28' (336") radius sanded into that top, the distance between the curve of the radius and a straight line from the front of the body to the top of the sound hole measure out to 0.005" which I am sure will close up once you install the neck so no gap should be there, let alone visible. You could wipe your rough fingers inbetween the two points to bring that amount of wood down. You Don't need a fancy jig to get this area flat, just a 6-8" length of hardwood run over the jointer with sandpaper will do.
if you rock the fb extension over the radius from one point to the other, there should be a maximum gap of 0.010" hardly much if you ask me. Just make sure that the top is flat (relative to the radius of course) when you glue down the fb extension.
So, as far as I can see, it's just easier to sand that area flat and be done with it.
PS, how do you guys get that fancy board and quote from a previous post into your post??
Guitars, no problem, forum editing that's my big problem. Rod True38604.885625
PostPosted: Fri Sep 09, 2005 1:45 pm
I think what Tracy is talking about is a scenario that happened in my guitar building class last night. Here is the issue...We are putting a 15 foot radius on the back and a 30 foot on the top. When glueing the sides together we leave our heelblock and tail blocks oversized by 5mm. The heel block would be 85mm and the end block 105mm. These will be planed down to a final measurement of 80mm and 100mm. We then plane the back of the rims down flush with the blocks and then use the radius dish to get to a 15 foot radius. We then turn the rims over and raius the top side of the rims to a 30 foot radius. Well, last night I had a couple of guys get heavy handed when sanding and the depth at the end block came out to 100mm and the heel block 72mm after radiusing the back and top of the rims. Here is the question... even though the depth of the rims is more than the standard 20mm difference from rear to front (end block to heel block) the guitar will be playable. The only thing we will need to do is put a larger neck angle on the neck to get the desired approx 3/8 inch gap at the bridge area. Is this correct? Instead of a standard 1 or 2 degree angle we would need a 4 or 5 degree angle for example. Comments????
PostPosted: Fri Sep 09, 2005 2:00 pm
But if you are radiusing the entire top area, you could theoreticall sand an inch off and still have the same radius in the rim right?
I think i'm in for some educating here, but if we are talking about the radius of the top, it really doesn't matter what the back does right, none of us make ovations which have very small radius' indeed. So, lets just get the back out of the equation if it doesn't need to be conserned with the problem . If I am wrong here, please correct me.
PostPosted: Fri Sep 09, 2005 2:05 pm
Of course if you lean the sanding board to the head of the body more than the tail, than the angle will change. So how do you guys with motorized sanding wheels ensure that you have taken the correct amount off of the front so as not to introduce a larger set angle?
Measure twice, sand once kind of thing?
PostPosted: Fri Sep 09, 2005 2:39 pm
What I was referring to was more of the radius, and you are right about there not being very much to sand. But what Robbie said is what I was looking at and that is why I was getting confused.
Rod, you are correct, we are talking about the top radius. But what happened in the class to a few students was that they sanded more heavily on the head block, and therefore introduced a back angle onto the top. So now it looks like they have a back angle on the top and back! So if there is that much of a angle from the back to the front(on the top), won't you have to compensate by making the neck angle greater?
By the way, the spinning disks that I saw usually lay flat and you just hold the sides in the mold against the spinning dish. So you can tilt it any way you want. Michael's setup is much more different than I have seen before, so I'm not sure how his will work in this situation.
Tracytl50736238604.9860532407
PostPosted: Fri Sep 09, 2005 3:42 pm
John Mayes use to have pics on his site of his shop and there was a pic of his rim sander setup.
John, any chance you could show us some pics of your setup for sanding the radius into the rims?
PostPosted: Fri Sep 09, 2005 4:04 pm
Rod,
FWIW, I don't think John radius' the sides before putting the kerfed linings on. That is why in his video, he raises the linings up in the middle about 1/16" and tapers them down to the headblock. Then he radius' the kerfed linings. I think the reason he does this is because he has a side template that he uses to cut the side radius into sides before bending. I don't do it that way because I have never built the same body style more than once, so I don't have a template to go by. Anyway, I was at his shop but don't remember seeing the sanding machine. Fess up John, where were you hiding it?
PostPosted: Fri Sep 09, 2005 7:12 pm
FWIW, you're talking about a very minimal amount of arch under the fingerboard, one which can be 'sanded out' with Lance's jig quite easily. Make sure you leave your top a little on the thicker side in that area if you're really worried about it (which shouldn't be a problem, because the part of the top with a fingerboard glued/bolted to it isn't going to be the most acosutically active).
This said, I've seen several different approaches. There's Michael's, which is leave the rims un-radiussed/flat, but angled back slightly above the waist, generally coupled with non-radiused bracing in the upper bout. I've also seen people who 'merely' don't radius the upper bout's bracing, but to radius to rims, people (like me, and I *think* Al Carruth) who radius all the bracing, and radius the whole rimset.
All of the methods work, just find the one that works best for you. Quite a few discussions on this topic in the MIMF library as well.
As for sides, I don't have profiling templates, because it just seems like an extra bit of hassle to me (lining them up correctly, etc. etc.), and it really only takes about 20 minutes, total, to get the sides trimmed (block plane) and radius sanded. I do this before I glue in the lining, because I feel it's much quicker and easier to chisel/saw/plane the rim down to roughly where it should be, clean up on the radius dishes in a few minutes, THEN glue the lining in slighly proud, and re-radius until the lining matches the rims (sanding only). Maybe 10 minutes at most for both top and back. Half an hour's work, excluding lining gluing time, and it lets me vary the depth easily, add a more or less dramatic wedge, no problems.
PostPosted: Fri Sep 09, 2005 10:40 pm
    I have some pictures of my sanding set up
http://www.bluescreekguitars.com/ar0007.htm
    As you can see the set is in the mold.I have it centered . I also pre form my set before bending so I don't have so much work to do. I first edge the rim with chalk so I know when I have it trued, and I also have a few reference marks so I can get it square and the proper wedge.
   Once the edge is true I glue in the kerfing just a tad over the rim and clean that up the same way.    john hall
PostPosted: Sat Sep 10, 2005 12:32 am
Thanks John
Cool system.
